6.0 vs 6.2
Old 01-31-2009, 08:28 AM
MonteCarlo31's Avatar
Originally Posted by jimmyboy8301
the downside to the 6.2 is that to the best of my knowledge it DOES NOT come with the 14 bolt like the 6.0 does.
It comes with the same 9.5" rear end that the 6.0 gets, it comes that way in the Denali line and Caddy line as well.
Old 02-01-2009, 05:52 AM
Z06.0's Avatar
im almost positive you can get 3.73s with the 6.2, if not its easy to swap gears, and as far as the centerconsole, ill trade you my jumpseat + cash for your center console
Old 02-01-2009, 07:51 AM
nighthawk08's Avatar
yeah it looks like if you order the max trailering pack on the SLT (LTZ) crew cab it comes with the 6.2L and 3.73 gears.
I would probably save some money and just get the 6.0 though. You have to remember that the 6 speed tranny has a 4.0 first gear which is why it usually comes with 3.42 gears.
Old 02-01-2009, 09:48 AM
I've checked the actual order guide and you can not get 3.73s w/ the 6.2 yet, I'm thinking that the 6.0 w/ a tune will be pretty close to the 6.2 when you figure in how under geared the 6.2 will be with 33" tires.
Old 02-01-2009, 01:57 PM
VMax's Avatar
Originally Posted by MonteCarlo31
I'm going to go 6.0 I think, I think there is still a bit left on the table with a minor tune and the 3.73s will really help out of the hole with a load.
get the 6.0 it is a strong motor and 3.73's are a must! Plus it has been out longer than the 6.2 so i am sure there is more performance parts and add ons for it. let me know how the 33's fit and what you do to fit them cuz i am due for some knew tires pretty soon and i would like to squeeze some 33's under my ride.
Old 02-01-2009, 06:20 PM
I'll be doing the truxxx kit with a rear leaf spring instead of blocks (blocks cause too much axle warp). I'll have the local spring shop slid in a extra leaf or two (maybe enough to take the standard block out too.
6.0 and 6.2 use the same heads and intake, I believe that the 6.2 is just a punched out version of the 6.0 w/o active fuel mgt.
Old 02-01-2009, 10:38 PM
VMax's Avatar
exact same heads, just a different bore the 6.2 has a larger bore. and you can probably squeeze more out of a tune in a 6.0 vs. a 6.2 I gained 65 hp and 73 lbs on a DYNO with a MTI tune. and Wheatleys tune was even better. I dont think those numbers can come out of a stock denali but i could be wrong. I just havnt heard of that
GMCtrk
18
10-06-2015 03:48 PM
turbo6c3
10-05-2015 06:11 PM
Cammed4ever
09-30-2015 03:38 PM
sTNT971
09-26-2015 04:22 PM
Quick Reply: 6.0 vs 6.2
