4l60e/4l65e/470el
4l60e/4l65e/470el
I'm curious what you guys found once you tore into your unit. Mainly accumulator springs, if the pistons were flipped, valve body changes, updates what else? The unit I am working on is a 2007. Same year as my truck. The original 60e I sold cause it was trash. On the current unit, I have an iss reluctor on the input but I have 4 pinion planets? GM budget cuts perhaps? The main reason I ask is cause I only saw updates up to 2006. In 07 the wiring went to 15 pins and is now 17 pins for most 2009 and up.
