4.8 is getting better!!! lol
Old Mar 7, 2012 | 09:09 AM
  #41
Originally Posted by cam
I have no idea why this exact phenomenon with the brakes is happening but there is VSS feeds on the front wheel hubs as well as the trans. I dont think there is a VSS feed for the rear wheels but I can swear to that. You could probably scale it in HP but Id still want to run the steelies and some skinnies up front. You'll shed more weight and lose rolling resistance which will improve et even more.
If you run two different tire heights, the vehicle either thinks the rear tires are spinning (during acceleration), or the fronts are starting to skid (during braking). If you run different sized tires in the front/rear, you have to remove the stabilitrak fuse...just don't engage 4wd (if you have it). Your ABS/Stabilitrak will be deactivated until the fuse goes back in.
Also, there are wheel speed sensors on all 4 corners, along with the trans output/transfer case speed sensor.
Old Mar 7, 2012 | 09:39 AM
  #42
cam's Avatar
cam
Ahhhh yes stabiltrak..... Im old school still brain stuck in traction control land lol.
Old Mar 7, 2012 | 12:17 PM
  #43
youngone2011's Avatar
Thanks a ton !!! Do u know which fuse by chance off the top of your head !!!
Old Mar 8, 2012 | 08:29 AM
  #44
Not off the top of my head, sorry...Should be pretty obvious when you see it...Might check the manual, as it will give a little more description than the fuse box will.
Old Mar 29, 2012 | 11:42 PM
  #45
bigwillys58's Avatar
I have 17" steels with 26" tall slicks for out back but I didn't run them last Friday cuz my tune is set for 31" tires . But yea I would like to be low 8 before spray
Holy moly! I like this due to the fact that im in the process of putting a setup together thats almost identical to yours aside of cam choice. plan on goin a smidge bigger. your 36-3800 stall, is it by chance a circle d? if so does it stall around that with the 4.10s or is it a bit lower? for me the higher the better...
Old Apr 1, 2012 | 12:36 AM
  #46
Ya it's a circle d trans and a stall , they told me it will stall about 3500 with 4.10s
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
AdaMax
May 16, 2016 11:35 PM
legerwn
56
Nov 15, 2015 10:21 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
