4.10's in max trailering sierra cc
Old 02-23-2011, 08:24 AM
BrutalSierra's Avatar
Default 4.10's in max trailering sierra cc
I was looking into putting some gears in my truck but have only seen the 10bolt..
I was told my truck has the 14 bolt HD rearend.
Has anyone put theses gears in a truck like mine? I can only imagine the pulling power this would add to such a strong truck!
Any info would be great!
Old 02-23-2011, 08:33 AM
ig109's Avatar
I would say that unless you are planning to run a bigger tire i would shy away from the 4.10s ...
With a 6L80 and 4.10 first gear would be useless..
Old 02-23-2011, 09:00 AM
CDN SS's Avatar
If you have a 14bolt you may already have 3.73 .if so going to 4.10 wont be much of a change withthe 6l80 ...........but if you have 3.42 yes 4.10 would be a great upgrade for towing 5000lb plus I ran 3.90 and wish I had gone
4.10 that allows you to run taller tire at some point too
Old 02-23-2011, 10:19 AM
Yeah i have the 3.42 rear gear.
Old 02-23-2011, 10:25 AM
Allgonoshow's Avatar
if it's a max trailer package it should have a 14bolt and 3.73's.
Does it have rear disc brakes?
Old 02-23-2011, 12:27 PM
It does have the rear disc's However since it's a Texas Edition it added other options one of which was a 3.42 gear.
Old 02-23-2011, 01:48 PM
ig109's Avatar
So you opted down to a 3.42 from a 3.73???
The rear disks are a part of the NHT towing package.. So are the 3.73s.. should have stayed with those and you wouldnt have to change two sets of gears....
Old 02-23-2011, 02:26 PM
I didn't have the option for 3.73's the Texas Edition truck only came with 3.42's And i wouldn't have got the texas edition however it had alot more rebates which took thousands off sticker price.
Old 02-23-2011, 03:19 PM
kstitz's Avatar
I tried to enter the Max Trailer Package with the Texas Addition and it will not let you enter both. Therefore I believe that you have the 6.2 without the Max Trailer package.
Kelly
Old 02-23-2011, 03:22 PM
I know it does. It's on my sticker and the hook up with trailer brakes as well as a built in trailer brake.
Quick Reply: 4.10's in max trailering sierra cc
