2009 SD rough idle and talling during cold start
Old Jul 25, 2010 | 02:07 PM
09Jimmy's Avatar
My 09 GMC 5.3 AFM does the exact same thing. The difference is mine is accompanied by a huge cloud of thick blue smoke. I figured it was the plugs momentarily fouling from the oil. If you try to feather the throttle to work through the stumbling it goes to 2,500 rpm and stays there, usually backfiring a couple times. GM says it's normal break in, even after giving them the "Excessive oil consumption on start up" TSB that they had never seen before.
I guess that's what happens when a gov't and union own an automaker.
Old Jul 26, 2010 | 09:57 AM
foreverkidd's Avatar
Registered User
Seemed to fix the problem guys.
Found a station with 94 octane fuel, tossed in a fuel system cleaner and conditioner and cleaned both the throttle body (which was caked with gunk) and MAFF.. seemed to even the idle
Old Jul 26, 2010 | 12:12 PM
Robert91RS's Avatar
You need to make some phone calls and visit your dealer every other week until they do something about it IMVHO.
Glad to hear it!
Old Jul 28, 2010 | 10:42 AM
Registered User
great.. so now after cleaning my maff and throttle body my truck seems to be revving higher and holding rev when i let off the throttle. this is causing my truck to downshift very roughly. it almost clunks between downshifts. WTF is up now? the butterfly seemed to move without any sticking when i was cleaning it, and i was very very careful using seafoam and a qtip whilst cleaning the maff
Old Jul 28, 2010 | 02:28 PM
Robert91RS's Avatar
You used a Q-tip on your MAF?!? OK, first things first. Pull your batt cables for a while and let the computer relearn. Then report back.
Old Jul 28, 2010 | 02:50 PM
Registered User
yes i used a q-tip, but i was extremely careful.. hands of a surgeon buddy.. i already did the battery pull because i was throwing a code after cleaning the maff, intake tube and throttle body.. i may do another one to see what happens..
Old Jul 28, 2010 | 04:29 PM
Robert91RS's Avatar
What code were you getting? Where are located?
Old Aug 3, 2010 | 11:11 AM
Registered User
im not sure on the code.. i will take it in to have it scanned. Im located in Calgary Alberta and Denver Colorado
superchomper2003
Aug 26, 2015 09:39 AM
fillpot
Jul 26, 2015 07:21 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
GRRR65GTO
Jul 10, 2015 08:27 PM
GreyChevy
Jul 7, 2015 08:57 PM
