11 sierra from hell
Old Feb 5, 2015 | 02:55 PM
Atomic's Avatar
I have a gauge for that
Sounds like a faulty regulator...
Old Feb 5, 2015 | 08:04 PM
Wareagle23's Avatar
Ok that's what I thought. That leads to my next question. I'm about to upgrade to fic1000 injectors. What would be involved in putting an adjustable fuel pressure regulator on there?
Old Feb 5, 2015 | 08:10 PM
03sierraslt's Avatar
You would have to build a return fuel system. If you need 1000cc injectors then you are gonna need one anyway as well as more fuel pump. You must be planning on adding allot of boost.
Old Feb 5, 2015 | 10:23 PM
Wareagle23's Avatar
Well I have a 76mm turbo and an inline bosch 044 on a switch. Currently on 7 lbs but it made a descent 396 to the wheels. A lot of kinks to work out. This injector thing is killing me
Old Feb 5, 2015 | 10:33 PM
Wareagle23's Avatar
Jake, I should pick your brain because I think we are kinda doing the same thing and maybe there are a lot of headaches you could save me. Like my evap system, maf, and my injectors. Oh and the throttle body (service traction control, stabilitrak) nightmare. It all seemed like such a great idea many thousands of dollars ago
Old Feb 5, 2015 | 11:20 PM
Jake75's Avatar
When you bleed it off is any air coming out?
Jake75- so you just converted to a return system?
no it was all gas coming out. just took a quick press and it would start right up
pick away man. i added the return regulator on mine and havent had the issue since.
Old Feb 5, 2015 | 11:43 PM
Wareagle23's Avatar
What kind and where did you get you regulator? Anything special that you had to do
Old Feb 6, 2015 | 12:31 AM
Jake75's Avatar
I used aeromotive boost referenced for the turbo. Nothing special just ran -8 for feed and -6 for return back to the tank
Old Feb 6, 2015 | 02:41 PM
Atomic's Avatar
That inline pump isnt doing anything for you fwiw.
Old Feb 7, 2015 | 02:30 PM
Wareagle23's Avatar
It's on a switch at the moment. So you are correct. What is your thought behind your statement
