08 Sierra skipping
Old Jun 21, 2025 | 05:22 PM
1redta's Avatar
Default 08 Sierra skipping
truck has 225,000 miles and started skipping at part throttle. No SES light but it is definitely annoying.
the engine is a 6.0 with 40,000 miles and this has happened before when it is hot ( NW Fl ) I’m thinking coils or old wires.
I ordered the Denso “performance coils” from Rock Auto. Has anyone run these before?
Old Jun 23, 2025 | 08:37 AM
BigKID's Avatar
Do you have a scanner? You can log misfires to see if it is isolated to a cylinder or bank before it throws a code. That will help narrow down the culprit. I doubt it is a coil though. Have you gotten gas from one of the hundreds of new gas stations going up in the area? Does it only skip at lower fuel levels?
Being a 2008 with a 6.0L swap, still running a 4L60? Could be transmission related too.
Old Jun 23, 2025 | 06:56 PM
1redta's Avatar
don’t mention transmission. ssshhhhhhhh
it does it in 2,3 and 4th
Old Jun 23, 2025 | 06:58 PM
1redta's Avatar
I bought the Denso” performance” coils from rock auto. and new 90mm throttle body
do the gas peddles for the dbw ever mess up?
Old Jun 24, 2025 | 01:57 PM
BigKID's Avatar
Usually if something electronic is out of parameters enough to cause issue, it will pop a code. If it is intermittent or short enough duration, it may only show as a pending code which does not set the light. You can still see the pending code with a scanner though.
Old Jun 24, 2025 | 05:33 PM
1redta's Avatar
found a spark plug wire that the metal clip over the spark plug was broken, it felt funny when I put plugs in, and part of the ignition coil harness pinched. probably from when I put the BTR valve covers on
Old Jun 26, 2025 | 02:30 PM
BigKID's Avatar
Sometimes it's that simple. Got to love an easy fix.
Old Jun 27, 2025 | 04:50 PM
1redta's Avatar
the gold 90mm throttle body is fun!!!
BIGDADDY1969
Oct 6, 2013 12:37 AM
chevrolade
Dec 11, 2012 08:21 AM
nighthawk08
Jan 31, 2009 03:54 PM
lucky77
Dec 2, 2008 08:43 PM
