08 Denali New Engine Build! Share your thoughts and opinions!
Old Nov 24, 2011 | 02:29 PM
LT1STRTOKER's Avatar
Default 08 Denali New Engine Build! Share your thoughts and opinions!
Ok so after 17000 miles on the new L92, milled heads, Comp VVt cam, springs etc etc, i sold my LT1 Trans Am and with the money I bought a LS3 based stroker.
My new setup consist of a LS3/ L92 block, Scat crank, Scat rods, Probe Pistons, a set of TEA stage two L92/LS3 heads with the double springs, ti retainers, and 73cc combustion chambers. Lunati cam, Comp short travel lifters, Yella Terra Rockers, MSD coils, melling hi vol/press pump, and I am finally gonna put the Vig 2800 multi converter in when we change the engine out. Truck still has stock 3.42 gearing with the 6L80 trans. I will also be stepping up from the 1 3/4 OBX headers to a Kooks 1 7/8 header, same Magnaflow 3 1/2 cat back.
There are a few things I would like to get opinions on, like throttle body and intake thoughts. Injectors, and what do you guys think happens to a cruise @ 83 17.4 mpg and cruise at 70 almost 19mpg fuel economy.
Old Nov 24, 2011 | 04:03 PM
Default Here are some photos I took before we started putting her together!
So I think this subject has been addressed before the actual effectiveness of the truck L92 intake. I have seen flow nyumbers of heads being flowed with the truck intake compared to the LS3 intake with heads bolted; but has anyone actually swapped and know if there are any tradeoffs in low end torque with truck intake and FAST car intake. Also is there a method of porting the truck intake to accept the 102 mm throttlebodies? My cam timing is mild to keep torque everywhere in the rpm range, but I would like to make the best of the ported heads I have had TEA port for me. Spoke with LS2 portworks but our intake is no longer availablke as a porting option through him, what do you guys think? Also I have saw where LS7 users are making 630+ hp with a stock injector, how does our L92 injector compare to the LS3 or
LS7 injector. What do you guys think. I have a week and 1 day to get these few options figured out, as I plan to finish the assembly and get this engine swapped out by next weekend.
Thanks guys for any thoughts!!
Old Nov 24, 2011 | 06:27 PM
62nalide's Avatar
how much for the L92?
Old Nov 28, 2011 | 01:08 AM
$3000.00 for the engine, pm me if there are any other details or questions on the engine needing answers.
Old Nov 28, 2011 | 06:16 AM
supercharged680's Avatar
how much for the headers only.. no y pipe
thanks man
Old Nov 28, 2011 | 10:30 AM
Originally Posted by supercharged680
how much for the headers only.. No y pipe
thanks man
pm sent!
Old Dec 7, 2011 | 12:09 AM
Default New engine in and up and running!
Ok guys new engine up and running, will post some new pics and a video by the weekend. Weather is bad right now out here.
Need to move out the engine i removed and make a great christmas gift for someone. Check my sig for engine details.
Thanks guys for your interest.
Kp
USMCvet0311
Aug 14, 2015 10:28 PM
Ammadien
Jul 22, 2015 08:50 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
Deceptarado
Jul 8, 2015 05:24 PM
