wires al way fouling/ burnign out
i am missfiring again this will be the 3rd set of wires in a year .
i have headers and they are 3 years old
IS THERE A PERMANENT FIX FOR THIS.
get these
protect the whole thing
you must be getting the wrong wires though cause mine dont even come close to my headers, you could always use a zip tie between the wires to kinda pull them closer together, like one zip tie from wire 1-3 and then 5-7, I did that on 5-7 just cause I didnt want the chance of them touching the steering shaft
The 1 near the shaft !
THE 1 NEAR THE SHAFT ALWAYS GIVE ME PROBLEMSget these
you must be getting the wrong wires though cause mine dont even come close to my headers, you could always use a zip tie between the wires to kinda pull them closer together, like one zip tie from wire 1-3 and then 5-7, I did that on 5-7 just cause I didnt want the chance of them touching the steering shaft[/QUOTE]
11 sec. Truck Mod
Here is how I prevent wire burn , never an issue on my truck .
I use heat sleeves , and took a stainless steel hose clamp , cut a section of it , drilled a hole in it so I could bolt it to the head using an existing tapped hole , and bent it to hold the wire back off the header .
Ok it looks sweet
Yeah that set up looks nice n neat but are those hole in head heads or what will i have to tap them ?
here is how i prevent wire burn , never an issue on my truck .
I use heat sleeves , and took a stainless steel hose clamp , cut a section of it , drilled a hole in it so i could bolt it to the head using an existing tapped hole , and bent it to hold the wire back off the header .
Thank you
Thanks i will have to look closer into this i replace way too many wires sets especially the the one nearest the shaft
thanks again now i need some metric bolts an thin strap stock
Wrecker 426
09-30-2015 09:39 PM
