Will it fit.........
Old Sep 23, 2007 | 03:16 PM
Mark Johnson's Avatar
Default Will it fit.........
OK guys- having tuned the truck and done away with the top speed limiter I ran into another problem. I bury the speedo at 100mph! I swear on a stack that is not hard to get up there at all. Been pokin ' around on ebay for an LS1 mostly for kicks, then I found a C5 'vette cluster, and the light went on.
The big question for you guys is- will the C5 cluster fit our trucks? Would be really cool if they did--------
Old Sep 23, 2007 | 03:19 PM
nightrunner's Avatar
Mr. Obvious
no the dash is shaped completely different, sorry
you should get a denali cluster, it has a 120mph speedo and a trans temp gauge and white needles, everything else is like stock. since your making your truck like a C3 anyways
Old Sep 23, 2007 | 03:27 PM
Yeah- I've tossed around the Denali/ C3 dash idea for some time, guess it just dropped outta my mind. Anyone else having this problem around 100 miles an hour? Problem is what do O do when I start aproaching 120MPH............
Old Sep 23, 2007 | 03:45 PM
truckmann's Avatar
Um slow down before you kill someone.
Old Sep 23, 2007 | 03:53 PM
Mr. Obvious
you dont have to get the whole dash, the cluster is a direct swap
this is my truck
crappy pic
Old Sep 26, 2007 | 07:21 PM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
Where did you get it from and how much did it cost with programming?
Old Sep 26, 2007 | 07:27 PM
Mr. Obvious
i bought mine on ebay for about $200 (cant remember) with a cracked front lense and swapped my old silverado one onto it. the denali one has a silver birch/goldish color lense, also what surrounds the gauges, black in my pic.
no programming necessary for the tran temp gauge, just plug it in and it works i havent had it programmed for my mileage yet but i will soon, ive heard certain dealerships can do it.
