When dp I change my Tranny Fluid?
Old May 11, 2007 | 06:19 PM
BlueRider's Avatar
Default When dp I change my Tranny Fluid?
I just hit 67K miles and do for an oil change, was wondering when I should change my tranny fluid, it's never been done. Thanks
Old May 11, 2007 | 06:25 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Yes, drop the pan and change the fluid! Every ~30K
Old May 11, 2007 | 07:11 PM
99RCSB's Avatar
Don't mean to thread jack as it does pretain to it,but when i change my trans fluid i'm going to be using Transynd. I'm told that synthetic maynot be good for the ol 4l60e. Any thoughts on this.
Old May 11, 2007 | 08:09 PM
trever1t's Avatar
I used to run M1 in my stock trans but i think now it's probably a waste of $. My FLT trans runs only Dex III.
Old May 11, 2007 | 08:11 PM
ReSpAwN DeMoN's Avatar
changings fluids are said to be done every 30K miles.. if you have rather high mileage (60+?) and are unaware of the history of fluid changing then you continue to change it every 30 but do not do a complete flush. DOing so can damage your tranny and/or shorten its life.
With this kinda thing in mind.. don't mind me for hijacking the thread..
I'm about to open my tranny up to install the servo's and the **** kit. I have no other choice but to change my fluid. Do I follow through with a flush? Or just replace the fluid/filter that was lost. I have 65,300 miles on an '03
Old May 12, 2007 | 08:56 AM
...yes...hell yes...Trever1t is right! I do mine every 20K miles but never let it go pas every 30K. Keeping the fluid clean and keeping an eye out for metal in the pad is the life of your tranny. And I woulden't hurt to put a deeper pan on there. The more fluid, the cooler the fluid, the longer the tranny lasts.
Old May 12, 2007 | 09:24 AM
bluecajun5.3's Avatar
11 Second Truck Club
this guy is right.
i would recommend you just changing the filter and fluid that was lost.
Old May 12, 2007 | 12:58 PM
PSM's Avatar
PSM
When you change the fluid, you don't actually get all of it out. I thought with a flush you atleast replace all the fluid
Old May 12, 2007 | 01:02 PM
trever1t's Avatar
With a flush, as the theory goes,if you haven't maintained service on a regular basis, you might dislodge gunk and cause failure.
Old May 12, 2007 | 01:21 PM
The ol faithful "change your tranny filter and loose your tranny" phenom! lol...I hate when that happens....and it DOES!
