whats the difference
Old Nov 15, 2006 | 08:14 AM
navy_ao_05's Avatar
Default whats the difference
whats the difference between posi, limited slip, and locker? sorry dumb question
Old Nov 15, 2006 | 09:45 AM
KY_BOB's Avatar
A posi and limited slip are the same thing. They use clutches to apply torque to both wheels when one slips. Posi-track was just a name that GM used years ago for their clutch type LSD.
A true locker (many will argue the the factory G80 isn't a true locker) engauges metal plates together to totally lock the rear end when one wheel slips and will stay locked untill torque is released.
Old Nov 15, 2006 | 03:33 PM
jakebdb56's Avatar
IMO the G80 is a true locker. I've never had it slip either side yet. I get badass traction with it too.
when you start looking into lockers too you'll find that there's mechanical, electrical, and air lockers. a lot of rock crawlers use air lockers along with a compressed nitro bottle (its either nitrogen or co2 I forget).
you'll also see what they call "spools". basically with a spool there is no planetary gear and carrier, the pinion drives the ring which drives both tires at the same rate all the time. spools are not for street.
hope the info helps
jake
twake_410
Apr 14, 2016 09:58 PM
wickedRCSB
Oct 30, 2015 09:45 PM
Staggered 02
Oct 9, 2015 05:19 PM
gmcyukon
Oct 5, 2015 06:20 AM
sTNT971
Sep 26, 2015 06:27 AM
