what oil do you run?
Old Nov 1, 2008 | 09:28 AM
02gmcbandit's Avatar
Default what oil do you run?
just curious to see what oil everyone's running
Old Nov 1, 2008 | 10:12 AM
chevrolet all the way's Avatar
did run mobil one synthetic but i got a damn good hookup on royal purple so i changed...
those are gonna be the 2 main choices on here i can betcha
Last edited by chevrolet all the way; Nov 1, 2008 at 10:12 AM. Reason: cant spell...
Old Nov 1, 2008 | 10:21 AM
hirdlej's Avatar
Pennzoil or QuakerState. I have crates of it in my back garage that I collected from 10 years ago when oil was 80 cents a quart. 6K-6500RPM shifts on all 3 of my trucks daily and never had a failure or have seen premature wear due to bad oil. I'm not going to argue that synthetics and modern oils aren't better, but what I will say is that if you buy the cheapest damn brand x oil you can find at your local farm supply store, you will not have your truck long enough or want to keep driving the same motor around long enough where you'll see any ill effects.
Old Nov 1, 2008 | 10:26 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
M1
The real answer is that as long as you use a quality lubricant, and change fluids religiously you wll be fine on a dyno or synth lube. I like M1 and have always run it since break-in.
Old Nov 1, 2008 | 10:30 AM
00ChevyScott's Avatar
Wearin' da big hat
Used to use mobil 1 5w30, but I get royal purple cheaper now, so I run their 5w30 now, as well as a lucas oil stabilizer
Old Nov 1, 2008 | 10:41 AM
andrew383's Avatar
traveling mod
mobil 1 in the ss
royal purple in the silvy
Old Nov 1, 2008 | 11:37 AM
Wheatley's Avatar
Truck Sponsor
Amsoil only
krambo's Avatar
Valvoline VR1 10W30. Not synthetic, High ZDPP. It is what I will be runing for the life of my 408.
Old Nov 1, 2008 | 11:44 AM
dirt track racer 81's Avatar
Valvoline 10w/30 switchin to VR1 next oil change
Old Nov 1, 2008 | 12:20 PM
Mark Johnson's Avatar
Valvoline 10w- 30 dino blend for the last 99,264.03 miles........................
