wats ur tranny temp run??
Old Mar 14, 2012 | 03:49 PM
Tim94gt's Avatar
12 Second Club
My stock 4l80 will run at 110-130 under normal driving, 150-160 when I beat on it. This tranny has about 10K miles on it using the factory cooler.
My original tranny ran similar temps until the dealer replaced my cooler lines, then it ran so hot:
It lasted about three days.
Old Mar 14, 2012 | 03:51 PM
AndysC3's Avatar
What is everyone using to get their temps? I've noticed that the trans temp in the cluster is WAY off. I have my Aeroforce gauge set to monitor trans and coolant temps.
And I bypassed the radiator.
Old Mar 14, 2012 | 05:43 PM
ak2007r6's Avatar
I just read off the OEM cluster but it was spot on with what HP Tuners was showing also.
Old Mar 14, 2012 | 06:28 PM
AndysC3's Avatar
Originally Posted by GMCtrk
Even with the Trucool 40k I've seen temps rise to 195* on AndyC3's truck.
Yea, it does get pretty warm when you do several back to back WOT runs.
Maybe they made it alittle more accurate than the older models.
Old Mar 14, 2012 | 08:27 PM
03 silverado's Avatar
i got 03 escalade gauges an my tranny temps right on
Old Mar 14, 2012 | 08:40 PM
2007chevy5.3l's Avatar
Originally Posted by 03 silverado
hey got a true cool 40k tranny cooler an it runs bout 130-140 wen its 80 degrees out, im jw wats normal
Same here, running a 3200 stall
Old Mar 15, 2012 | 01:26 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
AndysC3, maybe your cluster stepper motor is bad? I've seen a few that are off a bit, but the majority of clusters with trans temp gauges are pretty close.
It should also be said that it seems to be common that 80e's run hotter than 60/65e's by about 30-40 degrees, from what I've noticed. Even with 40K coolers.
Old Mar 15, 2012 | 10:01 AM
nonnieselman's Avatar
I just use efi live or a scan gauge 2.
And since my scan gauge is in my buddys truck i just used the laptop
Old Mar 15, 2012 | 11:21 AM
dmelvin's Avatar
Originally Posted by AKlowriderZ71
Mine runs at 135* almost 100% of the time. I don't think it ever gets to 150* at the track.
Do you have the cold weather bypass. I kinda need one for the winter, but it makes me a bit leery that it doesn't fully opens until 180*
Old Mar 15, 2012 | 11:25 AM
Yes, I run mine thru the radiator cooler. I also DO NOT use the cold-weather by-pass.
dewey
