Vortec Max minimum Octane
Old Oct 1, 2005 | 04:35 PM
OUT2WIN's Avatar
Originally Posted by GMJim
I just sold my 92 Corvette to buy this truck so I think I deserve the extra muscle.
Jim
I agree
Old Oct 1, 2005 | 08:19 PM
zippy's Avatar
this is the info directly from the gm dealerworld manual.
Gasoline Octane
For all vehicles, except those with the 6.0L V8 engine (VIN Code N), use regular unleaded gasoline with a posted octane rating of 87 or higher. If the octane rating is less than 87, you may notice an audible knocking noise when you drive, commonly referred to as spark knock. If this occurs, use a gasoline rated at 87 octane or higher as soon as possible. If you are using gasoline rated at 87 octane or higher and you hear heavy knocking, your engine needs service.
If your vehicle has the 6.0L V8 engine (VIN Code N), use premium unleaded gasoline with a posted octane rating of 91 or higher. You may also use regular unleaded gasoline rated at 87 octane or higher, but your vehicle's acceleration may be slightly reduced, and you may notice a slight audible knocking noise, commonly referred to as spark knock. If the octane is less than 87, you may notice a heavy knocking noise when you drive. If this occurs, use a gasoline rated at 87 octane or higher as soon as possible. Otherwise, you might damage your engine. If you are using gasoline rated at 87 octane or higher and you hear heavy knocking, your engine needs service.
Old Oct 2, 2005 | 09:11 AM
Mort's Avatar
Cool
One other thing to remember, aside from the price difference for the premium gasoline, is that the 6 will get 12.5mpg average empty and the 5.3 will get around 17.5mpg.
Old Oct 2, 2005 | 10:07 AM
zippy's Avatar
a 6.0L in a half ton gets much better than 12.5. hell, you can get that with a radix and a good size cam on a 6.0L in the awd version.
Old Oct 2, 2005 | 10:24 AM
1SlowHoe's Avatar
Destroyer of Transmissions
I have a 5.3 and only see 12mpg.
Old Oct 2, 2005 | 05:45 PM
OKcruising's Avatar
I had a 04 2wd SS, ran fine on 87 in oklahoma. Beat the snot out of it(literally, you'd be amazed at some of the stuff this truck can do on and offroad) every second, no knock for the 20K miles i put on it in a year (now its sold). Did put 91 in when it got over 100 degrees outside just in case though.
Old Oct 2, 2005 | 06:00 PM
zippy's Avatar
04' 2wd SS???
Old Oct 2, 2005 | 07:21 PM
Ross @ EDO's Avatar
FormerVendor
i can only run 91 or up octane in my lq9 or it will ping like crazy, so basically i run nothing but 93 octane since thats all we have.
Old Oct 2, 2005 | 07:34 PM
1SlowHoe's Avatar
Originally Posted by zippy
04' 2wd SS???
Yea, I thought they were AWD until 05?
Old Oct 2, 2005 | 07:48 PM
99Silver6.0's Avatar
91 Oc or mine will ping.
