Try to do the bosch 044 intank on a returnless fuel system
Old Dec 29, 2008 | 11:31 AM
NegraRCSB2X4auto's Avatar
Default Trying to install bosch 044 intank on a returnless fuel system
I've got my fuel pump apart and I've got an internal fuel regulator. Do I have to use this in order for my fuel system to work correctly right or can I bypass it?
Old Dec 29, 2008 | 12:27 PM
litreddevil's Avatar
Banned
no you can not by pass the reg. unless you are putting one in somewhere else
Old Dec 29, 2008 | 01:09 PM
Mangled03gmc's Avatar
Baltimore Whore
Yes you will def need to run a FPR somewhere else if you do away with the intank one..
Old Dec 29, 2008 | 08:27 PM
marlboroman71818's Avatar
Where is the in tank regulator? I have an 05 silverado and just put the pump in, is this not correct? I was under the impression the the to was voltage regulated by the ecm
Old Dec 30, 2008 | 07:36 AM
check this out:
http://www.magnacharger.com/pdf/manu...00-2003-06.pdf
Wareagle23
Aug 15, 2015 06:55 PM
TAPyvehc93
Aug 8, 2015 06:35 PM
MS3Z
Jul 30, 2015 06:17 PM
4B11T
Jul 13, 2015 03:48 PM
