truck wont stay on, put seafoam through throttle
Old Feb 22, 2010 | 11:50 PM
pasadenaman's Avatar
Default truck wont stay on, put seafoam through throttle
my truck had been mis fireing randomely so a friend suggested i pour some seafoam into the throttle. well i did 9less than an ounce , and the truck starts then rpms to 500 then cuts off. it would stay on to 1-1.5k with help of the gas pedal. let it sit for 4 hours and same thing.
Any ideas or suggestions?
Old Feb 23, 2010 | 12:29 AM
to make matters worse, now the fuel pump will not engage when the key is turn to the on position. my fuese chart under the hood is not correct because i replaced it a while back.
Old Feb 23, 2010 | 01:17 AM
Parke10's Avatar
grab a test light and start testing, or pull one by one.
Old Feb 24, 2010 | 06:34 AM
well i replaced the fuel pump relay and a few of the 10a fuses under the hood and the truck starts and dies down after a few seconds. i'll keep trying to get it to run. i had it jumped to another battery to make sure there was enough juice. i can hear the fuel pump engage now at least.
Old Feb 24, 2010 | 07:21 AM
****Problem resolved**** by replacing the fuel pump relay and a blown 10a fuse under the hood along with clearing the codes. until i cleared the ses light with a hand held it would not stay on.
wrb002
Aug 31, 2015 12:00 PM
black6spdz
Jul 16, 2015 01:32 AM
ROB 1 TON
Jul 13, 2015 04:43 PM
GreyChevy
Jul 7, 2015 08:57 PM
Gadgetized
Jul 7, 2015 04:40 PM
