truck slows down at 2-3 shift
Old Mar 7, 2005 | 07:42 PM
KeukaZ71's Avatar
Default truck slows down at 2-3 shift
my truck has no ***** lately. it seems very sluggish. while going at 50-70 mph at WOT, my truck use to pull like an animal. no it feels like there is alot of drag. when the rpm's get high right before the 2-3 shift, it stops accelerating. almost feels like a TM problem, but i never had this problem before.
could it be a fuel filter or pump instead?
Old Mar 8, 2005 | 06:27 PM
KeukaZ71's Avatar
no body knows. me too
Old Mar 8, 2005 | 07:28 PM
Well since its getting warmer, maybe your clutch fan is kicking in and dropping the anchor?
Old Mar 8, 2005 | 08:08 PM
KeukaZ71's Avatar
it is supposed to get down to 3*F here tonight.
hasn't gotten above 40*F in a long time.
i think it is either fuel pump, fuel filter, plugs wires, too large of a gap in spark plugs, or coils
Old Mar 8, 2005 | 09:59 PM
JERRY2500's Avatar
14 Second Truck Club
Trq. management is killing it.
Old Mar 8, 2005 | 10:02 PM
user 108208932024's Avatar
Banned
That is weird man.
What would TQ managament have to do with it if it just started?
Old Mar 8, 2005 | 10:41 PM
Kano's Avatar
maybe the cats are clogged
maybe the trannys slippin
who knows
ask about best exhaust, best intake, or best tuning
and you get many hits
but when a problem comes up...
I wish I knew
TO THE TOP
Old Mar 8, 2005 | 11:02 PM
If your cats are clogged, your slugishness should be rpm dependant not gear or speed. My next guess is tranny/converter. oh and its 72 over here in CA, I was at the beach today!
Old Mar 8, 2005 | 11:32 PM
dont know but one time my 99 ecsb z71 5.3 felt super slow it went like this, i hadnt moved it in a day or two i took it out around the block at 20 max then floored it but acted as if i tapped the throttle , i was just trin to impress but i got embarrased hehehe
Old Mar 8, 2005 | 11:34 PM
Kano's Avatar
more speed equals more load on the engine
I dont see why clogged cats couldnt be more readily felt
at higher speeds/ higher load/higher gear
I mean I can see what you're saying
in a controlled environment
like an engine dyno
He also noticed less power thru 2nd
1st gear is 3.06 so there is little time to feel a difference
I know what hes goin thru
I cut 1.8 60 fts
and slow *** ets
2 things Im troubleshooting is cats and transmission
2 worth checking IMO
