Truck Norris in a 6.0
Hey all, just picked up an 05 Esky with the 6.0 with 317 heads. I am wanting to put a cam in it, along with some long tubes I have from a previous project truck and then finally getting it tuned at a local speed shop that deals mostly in LS stuff.
I am not wanting to change the converter right now, so something on the more mild end is what i'm after. I want more power down low and mid-range, and a good noticeable lope.
I've seen a lot of guys running the truck norris from BTR in their 5.3's but not many in the 6.0. Do y'all think it would be suitable for me, or should I look into maybe the SS2 or another BTR truck cam?
Thank you.
Thank you.
You probably won't see the same lope as the smaller 5.3 liter. Smaller cubic inch engines sound off better than a larger engine with the same grind. I've had the SS2 in a stock LQ9 with headers and it performed well. I have a 3200 stall so I can't say how it will do with a stock converter. If your tuner can get a smooth idle in the 700's it may be tolerable. But the SS2 is not a low RPM performer... between the two... I would go with the Walker Texas Ranger camshaft.
And even at peak it's only down about 13hp. TN does pretty good for it's size even in larger motors. Might lose 20-25hp in a 6.0L but the torque below 5k would be stronger especially on a stock converter.
That's pretty similar to the "Sloppy Best" specs. @ 219/225 110.5+1.5. In a 5.7L the Truck Norris doesn't start loosing until after 5300rpm See the 12:00 mark: https://www.youtube.com/watch?v=qDZOM-m_xTY
And even at peak it's only down about 13hp. TL does pretty good for it's size even in larger motors. Might lose 2-25hp in a 6.0L but the torque below 5k would be stronger especially on a stock converter.
Another good choice would be the SUM-8728R1 which is around the same same. It has a pretty early intake valve closing, so it'd build great low and mid-range. And the extra lift on top would keep it still pulling strong up past 6k. Compared to the Norris, it'll have a little less lope, but still healthy.
