truck doesn't start
ok looking for so help. i just got done installing new convertor, new trans, new tune, and lt headers. everything is bolted back up and i was getting ready to crank it over to get the trans fluid to cycle, and i got nothing. the starter doesnt even crank it just does nothing. fuel pump turns on, and everything else but the starter doent seem to be turning on. i got under the truck and pulled the starter off everything is connected right, and the battery is fully charged. any ideas as to what could be happening?
im going to go back and double check all the connectors that i reinstalled.
How do I change this text
Does the starter have power with the key in the "Start" position? (Purple wire)
Check the Ing C fuse should be a 20 AMP, also there is a ING A fuse 40 AMP that feeds the starter relay.
Does the starter have battery power? Red 10 Gauge wire wich has a a fuseable link.
cams 98 silverado
Jul 31, 2015 07:36 AM
Mossyoakglock
Jul 17, 2015 08:30 AM
