trailer light help needed
Old Jun 22, 2005 | 08:35 PM
86SWB's Avatar
Default trailer light help needed
Does anybody have a wiring diagram showing the tail lights for a 2001 Tahoe? The left turn signal/stop light out put on the trailer light plug is not working. The left turn signal/stop light on the Tahoe is working.
Old Jun 22, 2005 | 09:55 PM
Rhino79's Avatar
9 Second Club
Do you use a round 7 to a 4 flat adapter or is yours just a 4 flat? I have seen those adapters screw up.
Old Jun 23, 2005 | 01:43 AM
thunder550's Avatar
High on diesel fumes
I run the 7 round to 4 flat adapter, had some corrosion or something built up on one of the contacts and make it stop working. Get a voltmeter and check the voltage on all the contacts coming out of the truck and be sure you know exactly where the problem is before you go tearing **** apart. Unless you already did....then by all means tear **** apart.
Old Jun 23, 2005 | 07:27 AM
86SWB's Avatar
Yeah that;s the problem. I'm not getting any power at teh 7 way plug on the Tahoe. The running lights blade and right turn/stop works. Its just the left turn/stop blade. I was looking in the owner's manual last night and saw where there is a fuse in the electrical box under the hood for trailer lights. Maybe it's one of them.
Old Jun 23, 2005 | 07:37 AM
JERRY2500's Avatar
14 Second Truck Club
Bingo, That's the problem. Drove me crazy one day trying to figure it out. It's the fuse
Old Jun 24, 2005 | 07:38 AM
86SWB's Avatar
FIXED!!! @#$% @$#@$ %#@%#@ @#$^%^% %$%$#@# %$%$#%# fuses!!
Old Jun 24, 2005 | 07:48 AM
JERRY2500's Avatar
Thats the same thing i said.
ZONES89RS
21
Sep 24, 2015 05:58 PM
Bluecollar Hotrods
Jul 16, 2015 08:52 PM
Aboss
Jul 9, 2015 10:28 AM
Sbrown06
Jul 9, 2015 09:21 AM
