TIG class is pretty dam cool
#41
Originally Posted by moregrip
I wasn't walking the cup on the lap joints. It's when the cup on the torch touches the weld bead and is used as a guide for your weld pattern.
#42
Banned
you can walk the cup any and all the time i do,the biggest thing you have to remember is no pressure just let the cup rest on what ever you r welding i will try to get a video at work.on some pipe wen we start.
i wish u guys were closer to me i could go help you'll
#45
Originally Posted by Stoichiometric
Do you mean pulse settings or direction of wash? I'm sorry I don't know the terms, I'm sorta self-taught with the welder.
#47
I usually move the torch in overhand circles holding the torch in my right and filler in my left. When you use a pulser it seems like you don't need to do anything besides advance the torch forward and add the filler in time with the pulses. When I was learning to add the filler at first, I would do good for about an inch and then add the filler to the tungsten, lol. It took me a while to keep everything moving in such a close arrangement without dipping the tungsten the puddle or hit it with the filler. After some time it will start to click.
#48
#49
For torch movement, I use whatever works at the time. If I do not have enough penetration in the the material, I will move the torch in a series of circles traveling in the direction of the weld. Otherwise, just straight down the line.
#50
Thanks Keith.
Pulse is turned off, the rest of the settings I stated above are accurate.
What does turning the pulse "ON" do for you?
I tried a circular motion tonight and the visual effect was much different; more like a stack of dimes then the pattern I have been using turns out.
Filler material is still a little wierd for me. It feels like I get some resistance on the rod up to a point and then the material just gets sucked right in.
