Throttle body bump stop grind?
Old Feb 9, 2004 | 04:05 AM
hondadream50's Avatar
where do you get do butterfly at? I want to port my throttlebody but need new butterfly.. Ls1 75mm need to port to around 79mmm thanks
Old Feb 9, 2004 | 06:55 AM
one03sierra's Avatar
Formerly one92rs
Talking
you need to stay under 4.65. that is the max. you probe the red lead from your meter to the blue wire on the bottom of the tps. then to ground for the other lead. closed voltage should be around .52 top .65. and the opening voltage should be no more than 4.65. just turn the key on and check your readings.
Old Feb 9, 2004 | 12:07 PM
Originally Posted by Y2K Silverado
Well I guess the HPP resets the code. After I use it to load either the same program or a new one, the SES light isn't there any more.
Jim
I don't know about the HPP#, but the Predator can read codes, run code tests (all or specefic ones) tell you what codes and the faults are when the SES light comes on AND CLEAR THEM. A very cool tool if you ask me. You can find them used on the boards or Ebay, if they're cheap enough they're good to have just for the diagnostic capabilities! IMHO of course!
jdb11386
Dec 3, 2015 09:34 PM
smokeshow
Aug 23, 2015 08:23 PM
GreyChevy
Jul 7, 2015 08:57 PM
Gadgetized
Jul 7, 2015 04:40 PM
