That cam has similar specs to my Comp LSR 265 grind though the Lunati has a little more lift.
I have LT's, HF cats, CircleD 3200 and 4.11's and love the way it pulls of the line. It pulls very good up top as well. |
What size tires/wheels are you running? Do any towing??
Im curious as to what kind of power it will make at the wheels..anybody guess what my current setup is making now?? |
Originally Posted by Fast_six oh
(Post 5270485)
Originally Posted by bobfig
(Post 5270541)
im thinking 330ish hp at the wheels would be my guess.
1 Attachment(s)
i was assuming before can with what you have now.
heres some one with a similar truck as yours on the dyno. and he added a tsp220 cam. https://www.performancetrucks.net/fo...-graph-519133/ Attachment 95128 |
Those are impressive numbers, my truck has the factory dual 2.75" exhaust..wonder how much difference there would be between that and his 3.5" single?? I wouldnt think too much..which cam would you pick for my application? The lunati 217/223 or the tsp 220??
for me i like being a little different and would go voodoo as a lot of people use the tsp220.
yes i would think i would up the exhaust to 3.5" all the way back also. |
Id like to keep it true duals..only other thing ill add is a h-pipe..i would think 3" Duals should be efficient or would stick with 2.5" duals??
well if you like the way it sounds now then i would leave everything the way it is till you get the torque converter and cam in.
Ok, yeah i like the way it sounds now, but i was unsure which setup would perform better after the cam converter etc..i assume the 3" duals would but would they be worth switching from what i have now (2.75")
