Temp/Compass Mirror into '01?
Old Apr 15, 2013 | 11:03 AM
Ferocity02's Avatar
Default Temp/Compass Mirror into '01?
My '01 Silverado doesn't have the fancy rear-view mirror with the compass and outside temp. Is it possible to add one relatively easily? There is a rectangular connector above the overhead console that doesn't go to anything. I figure it's for the mirror or the rear HVAC controls on an SUV model.
As far as I know mine doesn't have the outside air temp sensor, but will it have the connector and wiring for it? Or do I need the run the wires from the sensor to the mirror?
Do I need a 99-02 mirror or will an 03-06 work?
Thanks!
Old Apr 17, 2013 | 02:01 AM
Suburbazine's Avatar
The air sensor is normally located next to your power steering cooler. The wiring harness (if available) will also be in this vicinity.
You need the 00-02 mirror and the 00-02 sensor for this to work properly. I couldn't tell you if that connector in the ceiling is correct or not.
Corvette454l88
Sep 1, 2016 01:24 AM
FlyingLow
Nov 24, 2015 10:05 AM
RS/SS 4.8
Sep 18, 2015 11:41 PM
BCraven1018
Sep 18, 2015 08:57 PM
01 5.3
Sep 2, 2015 02:17 PM
