sugar in the gas tank
Old Oct 4, 2008 | 10:55 AM
RandomHero's Avatar
sugar isn't soluble in gasoline. It will just sit in the bottom of the tank. It won't do anything to your truck, but it will be a pain in the *** knowing it's there.
Old Oct 4, 2008 | 10:59 AM
kbracing96's Avatar
Upon further review sugar DOES NOT dissolve in gas, it stays in solid form. So for the most part, all it can do is plug you filter.
http://www.snopes.com/autos/grace/sugar.asp
viciousknid's Avatar
Where's the Beef?
It won't disolve but you'll be going through fuel filters like a ****.
Old Oct 4, 2008 | 11:20 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
that's fuked up right there, really. What people will do to another's property. Go buy a locking gas cap. Pull the bed and drian the tank thru a filter. Then get 12ga. load it with salt shot and stay up all night waiting for the punk to come back.
Old Oct 4, 2008 | 11:39 AM
shakesvho's Avatar
this has been on my list of things to do, going to get one today. sorry about what happen, i would drop the tank and clean it out, something like that would drive me crazy knowing its in there
Old Oct 4, 2008 | 11:46 AM
gtosilverado's Avatar
jack ur truck from the front, and make a hole on the rear of tank to drain it out plug it back up with something
Old Oct 4, 2008 | 02:44 PM
cwalker2006's Avatar
Talking
its a yukon denali lol....my gfs vehicle....and it was a biotch but, i got it finally looks nice and clean in there now i dont have to worry about pluggin filters all the time. my truck is still in good condition..so far i dont have ne problems with neone.
Old Oct 4, 2008 | 03:23 PM
magnetized's Avatar
How much was in there?
Old Oct 4, 2008 | 03:31 PM
not that much i really only saw it on the float didnt see much on the bottom so i pretty much did it for nothing...
Old Oct 14, 2008 | 10:43 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Much to everyones dis-believe enough sugar WILL cause problems. Will it harm the actuall engine??? NO most likely not. Here is what I personally have seen it do.
01 Tundra (I know thats the first problem but still...) Came in with cylinder #1 Miss fire. Went through all the mechanical Diagnostics. check compression, fuell pressure, pressure leak down, spark Plugs, look for lose conections, check for electrical continuity, Blah, blah, blah... SO we Replace the plugs, swaped coil packs and still had a problem. Even though all the injectos were firing and the fuel pressure was good we finally tore the injector rails off to see if there was a faulty injector. Guess what was wrong with Cylinder #1... It was was packed full of Sugar. How did I know it was sugar. It was white and sand like. Oh and I tasted it.....It was sweet so I knew it was sugar. we pulled the tank were we found at least a pound or 2 of sugar...
Remedy was first to have him call his insurance to cover the act of savatoage. They did.
Drop and flush the tank, replace pump, replace fuel filter, clean all Gas Lines with solvent and compressed air, clean fuel rails the same way, and replace all the comprmised injectors.
After we replaced the pump we decided to take the old one apart. It was a good thing we replaced it because it packed full of sugar. The sock filter was also full of sugar.
Oh and now for the kicker The gas door locks on that truck and guess who had the truck last??? His brother... He borrowed it while this poor guy was in the hospital. He was having open heart surgury to correct a problem they found. It was found during his check up in the emergency room after he passed out at the wheel of his semi and drove it into a ditch....
