Stuck wheel bearing removal with pic
Hello, I got a stuck wheel bearing. Just ended my second night of hammering on it, the old bearing has completely fallen about. I can't get it to break loose from the knuckle. Would it be a bad idea to take a blow torch to it? I'm out of ideas and exhausted.
just did mine this past saturday and it took 3.5 hours to do we mine were in because of rust end up getting a air chisel/hammer and hitting the **** outta all the way around and then beating the hell outta it with the sledge lol good luck bud i know the pain
13 Second Truck Club
Alright put the bolts back in use a air hammer on them pushing the hub out. Or find a way to use a slide hammer. But the air hammer trick I use up here in michigan. Works majority of the time had one fail out of 10
Keep in mind not to put bolts all the way in, I usually go about 5 threads in. until it starts moving then back them out some.
Good luck
Good luck
thread the bolts about halfway in, build yourself a nice little "ram rod" out of extensions, CAREFULLY (meaning keep fingers out) have assistant start the truck, and while turning the steering wheel...lodge your ram rod between the frame or somewhere on the suspension and the head of the bolt, and it'll pop out a bit, you may have to work side to side a couple times
this also works every time on dodge 2500 & 3500 amazingly
