steering wheel is shaking
Old Aug 22, 2006 | 09:03 AM
2k4tahoe's Avatar
Default steering wheel is shaking
i think its old age, i saw a thread once that i think there was a kit to rebuild it or something that fixed the shake.
Old Aug 22, 2006 | 04:45 PM
ClayB's Avatar
make sure your front tires are in good shape.. and the front end is aligned... if its not that.. i dont know
Old Aug 22, 2006 | 05:21 PM
redwagon's Avatar
shaking front to back? or slop in the steering left to right?
Old Aug 22, 2006 | 10:27 PM
budhayes3's Avatar
PT's Slowest Truck
Is it shaking while driving at highway speeds? Possibly a tire out of balance, or a shifted belt in one of the tires? Are the pressures set? A low tire will cause the steering wheel to wobble side to side. If you're experiencing the shaking only during braking, you may have a rotor that's out of round causing a brake pulsation. Other possibilities include worn steering and suspension components, worn/loose wheel bearing, etc.
Old Aug 23, 2006 | 07:59 AM
2k4tahoe's Avatar
ya i keep hearing tires, i think when i get the oil changed im going to get them to rotate the tires and see. thanks for the help guys, great help as always.
Old Aug 23, 2006 | 08:51 AM
2k4tahoe's Avatar
more like a bad wobble. its only cruising down the highway.
Old Aug 23, 2006 | 11:13 AM
redwagon's Avatar
see if you can wiggle your tie rod ends
Old Aug 23, 2006 | 11:25 AM
2k4tahoe's Avatar
thats true maybe my tie rods are wearing out.
Old Aug 23, 2006 | 11:34 PM
negativeswitches's Avatar
i ahve a balljoint going out and it causes my wheel to shake between 63 and 68mph
Old Aug 24, 2006 | 07:48 AM
2k4tahoe's Avatar
63 - 68 sounds close to where it does, interesting, i will look at it tonight again.
