Stainless steel hard lines
Old Feb 13, 2014 | 03:19 PM
  #21
black954's Avatar
Registered User
I had the wife pumping the pedal and I bled them. I had one of those power bleeders that clamps onto the master, but it was a leaking mess so I just do it the old fashioned way with clear tubing and a Gatorade bottle lol.
My rear calipers were also on the wrong side from the previous owner so I had to swap them side to side but the bleeders were still good.
Old Feb 16, 2014 | 02:03 AM
  #22
JCunningham's Avatar
I did a whole truck with stainless from summit. Had no problem flaring or bending. I bought there 25' sections and stainless fittings
Old Feb 26, 2014 | 08:28 PM
  #23
livefast1's Avatar
The ni-copp alloy lines are the way to go. I've probly replumbed 20 gm fullsizes in this stuff and it is really easy to work with. I can do a pickup in about 5 hours whereas a tahoe is a little bit more cramped and takes about 6-8 hours. A good flaring tool makes a big difference as well. I either use my mastercool flaring kit or a blue point compact flaring set. The ni-copp is really flexible and easy to contour around the frame.
Old Feb 27, 2014 | 09:12 AM
  #24
jaawood's Avatar
Where do you get the ni-copp alloy lines from?
Old Feb 27, 2014 | 10:48 AM
  #25
livefast1's Avatar
My local parts store. If yours doesn't sell rolls of them I believe jegs does. The stuff I use is Ni-Copp part number cnc-425. Also don't forget to order the abs block fittings as they're not super common. They're edelmann part number 121045.
SLOPONY
20
Oct 18, 2016 06:05 AM
FlowmasterMufflers
Aug 17, 2015 04:44 PM
thewrx
Aug 12, 2015 08:28 PM
mrgrim
Jul 8, 2015 08:12 AM
