smog check questions
Old Jan 25, 2007 | 10:18 PM
2004SSS's Avatar
Default smog check questions
does anyone know when a 2004 vehicle will need to be smogged? specifically in ca? i have done a few things that may raise some flags. i know i could pass the sniffer with some proper tunign and alchohol but the visual part is starting to make me think. the long tube headers i may be able to get away with since i have a carb eo from my tog's. but im going to be using the vic jr intake with a 90 mm tb and sheet metal elbow and i doubt that would fly. not to mention my blower says race blower not for street use(i have the carb legal one still and its an easy swap). i do have all of my stock parts just in case but id really like not to swap everything out. does anyone have any advice or any so cal folks that has a friend that could help me. could you please pm me and let me know or possibly help a fella out id appreciate it.
Old Jan 25, 2007 | 10:27 PM
dirt track racer 81's Avatar
sorry to be off topic..why not go to the 4 barrel throttle body?
Old Jan 25, 2007 | 10:33 PM
2004SSS's Avatar
because of the blower and how the blower pipe is routed. here is a pic to show what i mean , its going to be some work just to get it to fit with the vic jr but shoul dbe possible
not to mention i would have to go to a cable set up and i would like the better response with that but right now ive been murdering my money i have saved.
Old Jan 25, 2007 | 10:34 PM
opps..forgot you was drive bywire and had that style on intercooler
Old Jan 25, 2007 | 11:26 PM
xchevyx24's Avatar
anyways from my experances you have to get it smoged for the first time 7 years from the date first regesterd
Old Jan 26, 2007 | 12:12 AM
Posi12Bolt's Avatar
I believe its 6 years from the date of original registration...
Originally Posted by DMV
Beginning January 1, 2005, vehicles 6 or less model-years old are exempt from the biennial Smog Check inspection requirement. For vehicles with registration renewals due in the 2006 calendar year, this exemption includes model-years 2001, 2002, 2003, 2004, 2005 and 2006.
Old Jan 26, 2007 | 12:17 AM
Posi12Bolt's Avatar
looks like '09 or 2010 you'll be due depending on your trucks original reg. date!
Old Jan 26, 2007 | 12:26 AM
2004SSS's Avatar
yeah i guess thats nto to bad, at least i have some time to get everythign in and running good. but ill have to get some cats befroe i even try. thanks brian i shoul dhave known you would know.
Old Jan 26, 2007 | 12:44 AM
04Denali's Avatar
I was sure it was only 5 years
2004sss you have a PM
Old Jan 26, 2007 | 02:15 AM
TURBO8's Avatar
You might want to double check but I heard that if you are the second owner it's every two years after you buy it. I am not shure but that is what I heard. I think I read that you are the second owner, right?
