silverado nbs new battery dead
Old Feb 10, 2016 | 04:13 PM
vipergtrdj's Avatar
Default silverado nbs new battery dead
So I am chasing a battery drain somewhere and I am out of ideas. I replaced the battery with a new one, alternator charges at 14.7v. Once the battery is charged its good until it sits for 2-3 days , then is dead. One thing I noticed is the alternator housing gets to 160degrees (tested with my temperature gun). I think thats a little warm but no idea if it means anything. Could the alternator be draining the battery?
I have a few things wired to the battery through the fuse panel, heated/ powered seats (both turn off with the ignition key), HID headlights (off with key), subwoofer and amp (off with key). I verified they all turn off with no draw.
Old Feb 10, 2016 | 05:36 PM
Suburbazine's Avatar
Disconnect positive cable, put an incandescent (NOT LED) test light between the battery and the cable. Pull fuses (pull, replace one at a time) until light goes out. Go for the headlights and AC first, it's not uncommon that the switches fail and pull current all the time.
Old Feb 10, 2016 | 08:07 PM
Wolftrk99's Avatar
Ive gone through same problem, ended up being the dimmer switch in the headlight switch drawing current...
Old Feb 10, 2016 | 08:16 PM
vipergtrdj's Avatar
K. Thanks for the tip. Wouldn't certain things cause a small draw even when off, like radio and ecu ? Or no?
Also, the alternator being hot?
Old Feb 10, 2016 | 08:18 PM
Wolftrk99's Avatar
If the alternator is overcharging and over heating the battery yes it could cause a loss of voltage on the battery, due to essentially frying the battery... Altermator could also get hot trying to compensate for a dying battery, very rare for an alternator to pull a draw when the key is off....have seen it but its rare
Old Feb 11, 2016 | 09:53 AM
vipergtrdj's Avatar
I did a test and found the radio circuit was drawing power when off. Amp meter read 2amps. I pulled the radio fuse and draw went down to 4 or 5 milliamps. So I pull the radio and unplugged it. Draw was still at 2amps. I checked my autometer gauges and unhooked them from the radio switched wire, draw went down to 4 or 5milliamps. I plug in the radio and draw was still low. I hook the gauges back up and draw went to 2amps. So looks like the gauges are the cause.
Would wiring in a relay fix the problem so the gauges won't drain the battery ? Wire it so the switched 12v powers the relay coil.
Old Feb 11, 2016 | 11:57 AM
Wolftrk99's Avatar
Guages should be on a switched feed anyway, they dont need constant power...
Striker2237
Feb 23, 2016 12:09 AM
01SilveradoJakee
Feb 12, 2016 08:08 PM
dantheman1540
18
Feb 7, 2016 10:04 PM
Chaney3000
Feb 4, 2016 07:00 PM
aksz71
Jan 14, 2016 06:55 PM
