Should I sell?
Old Jun 19, 2012 | 07:41 PM
langan's Avatar
Somewhere on here says its 100-110 lbs? Can some one post a picture of 6.0 with trans? I think I am missing some eletronics on the 4l80 and on engine there is a hole for something behind TB on intake. Trying to make sure I have everything it was engine one place trans and wire another.
Old Jun 19, 2012 | 07:42 PM
JFOLM's Avatar
Guys, keep in mine that he bought them as complete running packages... Complete engine, with transmissions, wiring, computer, and so on.
The 6.0 package may have been a little steep, but with under 40K miles is probably not to bad.
You are right. I actually skimmed right over that. Those really aren't that bad of deals OP. It is hard to find low mileage engines now.
Old Jun 19, 2012 | 07:43 PM
JFOLM's Avatar
Maybe the hole behind the TB is for the EGR. They have plugs for that hole.
Old Jun 19, 2012 | 07:49 PM
langan's Avatar
Heres some pictures
Attached Thumbnails Should I sell?-p1010001.jpg   Should I sell?-p1010002.jpg   Should I sell?-p1010003.jpg   Should I sell?-p1010004.jpg   Should I sell?-p1010005.jpg
Old Jun 19, 2012 | 10:26 PM
rj2's Avatar
rj2
Then keep what you have. If your doing a build anyway then just buy the heads and pan you want and sell yours after u take them off. And with low miles whatever else u upgrade the stock part will probably sell since it doesnt have 100k miles on it.
Old Oct 17, 2012 | 05:37 PM
langan's Avatar
Well since they did not sell going to use in the two old trucks
Old Nov 25, 2012 | 10:17 PM
langan's Avatar
Well it fit kinda have no ideas how or where to fit Maf and air cleaner? Suggestions please
Attached Thumbnails Should I sell?-p1010001.jpg   Should I sell?-p1010005.jpg   Should I sell?-p1010002.jpg
Old Nov 25, 2012 | 10:24 PM
langan's Avatar
If I switch out truck manifold for a LS1 then maybe I could do a U bend and place aircleaner on top of manifold? I here truck manifold beter for a driver and I have no idea of parts need for swap? Man,fuel rails,TB,belt tensioner relocator or water pump am I close?
Old Nov 25, 2012 | 10:52 PM
1FastBrick's Avatar
Custm2500's Rude Friend
I missed your post earlier but yes the port directly behind the TB is for the EGR.
If you want to run an LS1 Intake you will need the complete set up with fuel injectors and rails. The plugs on the injectors will be different so you will have to change the plugs or buy adapters.
On a set up like yours you can modify the fire wall and run the intake backwards or run the intake tube inside the cab.
Other wise you may have to switch to a carb style manifold and run the TB on top with an Elbow.
Old Nov 26, 2012 | 09:05 PM
langan's Avatar
Cool I can turn manifold around? Still use same parts?
