should I get a 6.0 gas or duramax?
Old Feb 7, 2011 | 09:47 PM
Spoolin's Avatar
GFYS and STFU
Diesel Diesel Diesel!!!
Old Feb 7, 2011 | 10:31 PM
02HD's Avatar
Originally Posted by smokeshow
You'd probably end up paying someone to beat some sense into you if you bought a 6.0 truck for towing a 20 foot gooseneck... I wouldn't say the 8.1 is a good alternative either, because it does not get the same mileage as a 6.0... Regardless, hook a trailer up to either one and they will suck down the gas. Diesel FTW if you plan on extensive towing.
I pull a 24 foot gooseneck regularly full of cattle and can pull just as hard as my buddy with the same truck only his is a dirtymax. and yes I drop from about 13 to about 10 and he gets about 13 pulling. and I am not anywhere near flatland either.
Old Feb 9, 2011 | 10:20 AM
Sc00by's Avatar
D-max for sure. for heavy towing the diesel will last longer and give you better MPG. Plus with some basic mods they can be pretty quick.
Old Feb 9, 2011 | 06:52 PM
Being a mechanic I say a 8.1 if you want to keep it out of the shop.
Or diesel if you got deep pockets to fix it when it goes down.
Old Feb 9, 2011 | 07:05 PM
TIM Z's Avatar
11 sec. Truck Mod
The only Duramax that could apply to that theory would be the 01-04 LB7 due to hit or miss injectors.
All other years all very very reliable.
But yes, performance builds are very pricey but thats not eeven the subject here.
I have 63,000 on mine, owned it since it had 1 mile, and its been tuned since 500 miles and ZERO mechanical problems.
8.1s IIRC have valve spring or head issues ?
Old Feb 20, 2011 | 09:22 AM
black 6.0's Avatar
I have a 6.0 i have pulled a 14000 pound pulling tractor a good bit it relly likes to turn some rpms mpgs aroud 9-10 and around 15 empty driving right i can top a 7 mile 6% grade at 50 with that load
Old Feb 20, 2011 | 11:46 AM
xsports33's Avatar
+1 for the duramax... i plan on heading in that direction sometime in the future
Old Feb 20, 2011 | 11:55 AM
06Sierra2's Avatar
man i would do a dmax, tuned with some gears. that be some badass low end tq for towing
Old Feb 20, 2011 | 02:16 PM
Country Boy's Avatar
Senior Member
I wouldnt buy a Max unless you have some decent money to blow and have the need for one. When they do mess up, its very expensive to fix. **** does happen. Gassers are easier to maintain, cheaper to maintain, cheaper to fix, and much cheaper to buy.
Old Feb 21, 2011 | 01:15 PM
ap2002's Avatar
Ive had both, and thats why i have a dmax now, there is no comparison between the two. Its plain and simple get a diesel!
Tigger Welder
Oct 1, 2015 08:41 AM
mitchellmade
Sep 27, 2015 08:27 PM
racedad70
Sep 16, 2015 01:51 PM
chvy=power
Sep 8, 2015 11:06 AM
