Rust Bubbles
Old Sep 8, 2005 | 12:37 PM
JayBirdWs6's Avatar
Default Rust Bubbles
I pulled up a standard bedliner from the previous owner and found just some rust bubbles not to bad but when i washed it and rubbed my finger over the rust bubbles the yellow stuff washed away but there's still little bubbles there. How do i go about taking care of this problem? Im looking at getting the truck repainted in the spring along with a line-x or rhino lining.
Old Sep 8, 2005 | 12:44 PM
Fogle07's Avatar
if you plan on putting a spray in bedliner in it later then just clean up all that rust and make sure its only surface rust then spray a little paint on it if your going to keep that drop in liner in there untill then. it should be ok till you get a spray in.
Old Sep 8, 2005 | 03:37 PM
JayBirdWs6's Avatar
thanks man.
Old Sep 8, 2005 | 03:40 PM
Fogle07's Avatar
anytime. make sure you put something pretty good on there that will last under that liner till you can get a spray in.
TAPyvehc93
Jan 8, 2016 10:47 AM
dsbodley
Nov 14, 2015 09:46 PM
trxmxzx
Sep 29, 2015 07:42 AM
Closer_2001
Sep 16, 2015 11:46 AM
