residue on doors from de-molding
Old Apr 1, 2010 | 12:58 PM
its already been said, but an eraser wheel on an air or electric drill works the best.
Old Apr 1, 2010 | 06:14 PM
Evil Eric's Avatar
I think I used sticker off from walmart. I found it in the sporting goods section in the boating accessories. Had the same scent as orange glo.
Old Apr 1, 2010 | 06:28 PM
00ChevyScott's Avatar
Wearin' da big hat
Used the thumb method for most of it, and the stripe off 3M eraser wheel for the remaining stuff. Be careful with it though as it can definitely burn through your clear coat if you're not careful.
Most of the busier/larger oreilly stores carry it, but all of them can order it and have it same day/next day if you ask them.
Old Apr 2, 2010 | 12:01 PM
05TahoeSS's Avatar
What is the best way to start the side moldings off... just start pulling???!!!! lol
Old Apr 2, 2010 | 02:48 PM
Mrgoodwrench3's Avatar
I start by using a very strong thin string. Loop it around a finger on each hand, slip it behind the molding, use a back and forth motion to cut through the tape. Once it is started you can pull it off. It also helps to use cold water on the moldings. It tends to make the tape more brittle and easier to pull off.
Old Apr 5, 2010 | 08:27 PM
camochevy21's Avatar
Originally Posted by andrew383
I used googone when i removed my side moldings...
When i do it, I heat it up a little bit with the heat gun. . . spray on the goo gone then hit it again just to warm it up a little with the gun and then wipe it clean with a rag and a little elbow grease.
rumblebox
Oct 29, 2015 10:35 AM
BCraven1018
Oct 1, 2015 08:22 PM
RS/SS 4.8
Sep 17, 2015 09:17 PM
SWINGRRRR
Sep 3, 2015 07:49 PM
