removing door panels
Old Jun 10, 2009 | 07:38 PM
whitegmc2003's Avatar
Default removing door panels
the tray things in the door of the sierra's.. how do you remove them?
Old Jun 10, 2009 | 07:41 PM
006rcsb's Avatar
should be a screw on the very bottom of the door panel that holds it in, that how mine were, its a silverado but im sure there isnt much difference.
Old Jun 10, 2009 | 07:52 PM
Mangled03gmc's Avatar
Baltimore Whore
Tray?? Not sure what your talking about. But there are 2 screws at the bottom of the door, 2 under the arm rest, 1 behind the lock(slide)
Then you have to pop the panel out that is around the door handle, the one that is at the top front of the door.. Lift up and pull out
Old Jun 10, 2009 | 08:04 PM
yes sorry the tray near the bottom of the door
Old Jun 10, 2009 | 08:10 PM
GMCtrk's Avatar
screw on the underside of the panel
Old Jun 11, 2009 | 12:26 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
You gotta remove the door panel from the door, before you can remove the pocket/tray from the door panel.
Old Jun 14, 2009 | 03:59 PM
thanks everyone
FlyingLow
Nov 24, 2015 10:05 AM
cheyenne383
Nov 13, 2015 09:24 AM
rumblebox
Oct 29, 2015 10:35 AM
03sierraslt
14
Oct 9, 2015 05:53 AM
