REALLY need help with brakes
Hi guys, first off I have used the search feature and was unable to find any threads pertaining to what is going on with my truck. I just bought it yesterday, 2004 RCSB 4.8 auto 2wd apx. 70,000 mi. It has a few problems, Odometer reads Odometer : Error, Speedometer jumps around, and it has some brake problems. The situation is this : The front brakes are not applying whatsoever, the pedal goes all the way to the floor before the rear brakes engage and there is no resistance. The calipers and master cylinder have all been bled and dont contain any air. The master cylinder has been replaced twice. The Service Brake System message is displayed and the brake light is on. Any suggestions? I am going to school soon to try and use the Tech II to bleed the Brake Pressure Modulator Valve. Is there any chance that both calipers have gone bad? Any way to check for a bad caliper? Any and all hep is appreciated.
If you have access to a tech 2 then you need to scan for codes in all the systems to see whats going on.
As far as the Cluster they are known for having bad stepper motors. To know for sure you need to scan for codes and Sweep the gauges to see if the function properly. Its well documented all over the internet.
It also sounds like you need to scan for codes in the ABS system. Usually when the service brakes soon light come on its an indication of a failure. Could be wiring, could be a sensor, could be a module, could be as simple as a fuse. Any time you service the brake system you should use the Tech 2 to bleed the system internally. It cycles the pump and all the valves to insure there is no air in there.
If your in some type of an automotive program the instructor should be able to walk you through all of this and help you diagnose it.
If there are codes present's it will at least point you in the right direction.
