Race A Lightning
Old Mar 14, 2005 | 09:21 PM
stock Lightnings are slow. mine ran only 13.80s @ 100 mph. some guys this time of year in the cold are can push 13.5-13.6. esp the newer 03-04s. much stronger than the 99-00.
pullied and chiped, different story.
Old Mar 14, 2005 | 09:40 PM
whats up gator hadnt seen you in a while.
Old Mar 14, 2005 | 09:45 PM
should i go back down to a 3.73 rear end?or should i stick with the 4.10 ratio. this is my every day driver vehicle
would this be a good cam .224 .230 .581 .588 112lsa be the size cam i need and would i need to do any piston or head work to make this cam work.
please help!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Mar 14, 2005 | 10:05 PM
goshawk23's Avatar
Truck addict
some springs for sure for that cam. if you can get the heads cleaned up some it will help a lot. no need to change the setup for that cam.
what size tire you planning on running with that setup? dr's at the track i hope. cause if you don't. guess what, you won't stop spinning by the time you hit the 1/8 mile mark.
as far as the stock L yea i think with that setup and traction you should have him covered. but like mentioned. pullied and chipped L. well, be on your A game cause those things run hard.
Old Mar 14, 2005 | 10:43 PM
i have been around. been busy moding. i still vist the truck forum from time to time. just to see if there are any new products for the wife's yukon
Old Mar 14, 2005 | 10:54 PM
should i go back down to a 3.73 locker would that be the better rearend for me since this is my ever day driver. i reordered me a new cam it is .224 .228 .581 .588 114lsa is that one good enough cam for my stall or is it to big please help
Old Mar 14, 2005 | 11:06 PM
Kano's Avatar
Id keep the 410s
and put them on an eaton posi
Old Mar 14, 2005 | 11:08 PM
goshawk23's Avatar
Truck addict
agreed with gamdawg. just make sure you have some et streets or equivlenant to launch at the track...
Old Mar 14, 2005 | 11:20 PM
Ok Thanks. Is My New Cam Big Enough For My Yank 3200 Stall And 4.10 Ratio Or Should I Go Smaller
Please Help!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Mar 14, 2005 | 11:34 PM
Kano's Avatar
I dont know what else to say
looks like a good well matched setup
hmm
Id run a tall et street with the 410s
to the top
Im no genious
maybe someone else will chime in for ya
