Quick Response Guys!!!
Old Nov 19, 2005 | 03:10 AM
Do 50/50 only if you have freezing conditions. Other then that, you can go roughly 70/30, water/coolant. Then some water wetter for good measure too.
Water has better cooling properties then coolant does. The word coolant is actually a misnomer, in that it doesn't really help cool, but rather prevent corrosion and freezing from the water in the system.
Water Wetter also has some of those qualities that coolant offers. But I'm not sure how effective it is on it's own.
Here in SoCal, I can run 80/20 and not give a damn
Old Nov 19, 2005 | 09:03 AM
budhayes3's Avatar
PT's Slowest Truck
I've gotten it at WalMart or K-Mart here in Jersey...I like the pre-mixed stuff, makes it easy to get the right amount
Old Nov 19, 2005 | 04:09 PM
04BlackSilverado's Avatar
I run 80-20 the other way, 80 coolant, 20 water, for two reasons, 1) I don't tow and cooling is never a problem, even when at 100 degrees and 2) I dont make a lot of power so its just not that important right now.
It can get well below 0 around here in the winter, it depends on where you are in the world.
Old Nov 27, 2005 | 11:44 AM
FS560's Avatar
Mixtures over 70% antifreeze provide less freezing protection than the optimum 70/30.
Since dexcool is also glycol this parameter should not change.
BKnBLK05
Dec 28, 2015 08:52 PM
fillpot
Jul 26, 2015 07:21 PM
ls2 dude
Jul 25, 2015 11:08 PM
lxcoupe
Jul 21, 2015 02:12 AM
GM-only
Jul 19, 2015 10:48 PM
