Pulling heads
Old 08-28-2014, 11:34 AM
N/ALS1's Avatar
Ok so I had some time to actually pull one side. The coolant kept on flowing, I think it spilled half of the radiator.
Second thing, is there suppose to be a little bit of oil on the threads? The lq4 block was bored .030 over and there was a little pieces (not many) of metal. I will chase it with a thread chaser and then put some thread sealant if need be when it goes back together. Let me know what you think.
Old 08-28-2014, 11:47 AM
pittman's Avatar
Be sure that you wash that coolant out into the grass real good if you like animals. It is like cool-ade to them and it will kill them.
Old 08-28-2014, 11:50 AM
N/ALS1's Avatar
Yeah it was in my garage so I had to wash it all down. Left water flowing for that reason.
Old 08-28-2014, 09:54 PM
Suburbazine's Avatar
Don't use thread sealant in the head bolt holes, it will affect the torque limits of the bolts and block.
Oil on the threads happens normally, a little bit will seep around the head gasket and into the bolt wells, then more will get spread when you loosen the head.
Old 08-29-2014, 02:08 AM
N/ALS1's Avatar
Ok I was starting to get worried. So don't put anything on the threads?
Old 08-29-2014, 07:17 AM
I have a gauge for that
Atomic's Avatar
Nope, install them dry.
Old 08-29-2014, 09:06 AM
06murder's Avatar
Block has cooliant drowns on it on both sides there Allen heads
Old 08-29-2014, 05:58 PM
Also when reinstalling the heads, make sure you follow the torque sequence and stages to a T. If you happen to tighten the wrong bolt in the sequence (or the right one to the wrong spec) you can potentially cause the crush layers in the head gasket to develop a wrinkle- bad juju.
Old 08-29-2014, 09:33 PM
Tootall's Avatar
whenever I pull a set of heads off of a working/running engine, I use a shop vac to suck out all of the coolant.
I always pull the largest hose off of the water pump first with the shop vac already going, then the heater hoses. After that the radiator and water pump can be pulled with out spilling a drop.
When the water pump is pulled, put a suction on the lower side, . . . this clears the coolant from the heads. Keeps most of the water out of the bolt holes for the heads.
If you don't have tap to chase the head bolts with, use a stock head bolt, and grind both sides down like a make shift tap.
I have reused a set of stock 5.3/5.7 MLS head gaskets and the stock TTY head bolts, but I do not recommend it.
Old 08-29-2014, 11:45 PM
N/ALS1's Avatar
Appreciate the info. Next time will have to remove the w/p. live and learn.
Quick Reply: Pulling heads
