pulled codes....
Old May 26, 2016 | 05:38 PM
40series's Avatar
Default pulled codes....
c0305,c0227, c0300, c0321, u1255,u1000,u1251
c0327, c0359,c0374,c0379, c0550,b0790,p0442
engine lights been on for a few days these came up at the parts store what ?
Old May 26, 2016 | 05:47 PM
FFDP's Avatar
The C, U and B codes shouldn't set the engine light, but that P0442 will.
A higher tech scanner could see if those other codes are just history codes or are actually thrown codes from the BCM functions/climate control etc etc.
P0442 means small evap leak. Might from a loose gas cap, or bad seal on the gas cap or a small leak somewhere else.
Old May 26, 2016 | 06:52 PM
40series's Avatar
Default auto zone says .....
auto zone said its a ( evap )purge valve solinoid...part cost 34.00 he told me the lucas gas treatment might make it go away?
Old May 26, 2016 | 07:25 PM
Wolftrk99's Avatar
Gas treatment isnt going to make an evap leak go away... P0442 is "usually" caused by a bad seal on the gas cap or a small pin hole in an evap line somewhere...
Old May 26, 2016 | 07:29 PM
Wolftrk99's Avatar
C0305 is rear speed sensor code. And i think the c0355 is a code for park switch....
willhorne22
Aug 27, 2017 10:01 AM
ewr3ck18
May 21, 2016 12:59 AM
renright83
May 20, 2016 10:02 AM
98silvertacrbn
May 16, 2016 03:14 PM
Jlipton72
May 12, 2016 09:55 PM
