Power steering
2nd fastest 5.3 ECSB
Why is it that after I wash the truck that the power steering seems to work so well? Only thing I can think of is that the tires are turning easier because their damp but it seems to work better for a while after the truck is fully dry.
No, I'm serious!
No, I'm serious!
normally when the truck is parked it's a little difficult to turn the wheel hard over at idle...I have 285's if that makes any difference. When I wash the undercarriage at the car wash the wheels turn like old school power steering, easy!
I know mine does get hung up once in a while when i go from drive to reverse to back up in the drive way. My dad just got a 04 silverado and his does the same thing. I have 315's and he has 265's.
When is the last time the fluid was changed?
Most car owners already know how important it is to change certain fluids in their vehicle. Oil changes quickly become part of a regular routine but there are other essential fluid changes that can become overlooked. Your power steering fluid is easily one of the most important working fluids within your car. It is a hydraulic fluid that provides power to the steering aspects of your vehicle. Despite being so important, the cost of power steering fluid is not all that high. This needs to be a regularly scheduled part of your car's maintenance. It certainly does not hurt to create a calendar that lists these upcoming fluid changes.
It is important to understand how essential power steering is to your driving experience. It is quite literally what keeps you on the road and going in the right direction. By making sure to change power steering fluid often, you are ensuring both your safety as well as the longevity of your car. Taking the time to do an inexpensive fluid change can in fact keep the steering components of your car is proper working condition. By neglecting to perform these maintenance tasks, you put yourself at an unnecessary risk of injury. Replacing worn steering components in the future will not be an enjoyable experience either.
Many drivers may not realize how hard the power steering actually works. The entire purpose of the fluid is to allow you to drive in comfort and ease. It needs to be able to work properly in all types of driving conditions as well as weather types and temperature changes. Steering the car is easy because of the fluid providing the right hydraulic pressure so that the steering is smooth and not difficult in any way. If you decide to neglect the maintenance of your power steering, then you can expect to experience things like wear and tear that could have been prevented. If damaged pieces fall into the remaining fluid, you will have a lot of trouble on your hands.
First of all, it is extremely important to put your power steering fluid change on a schedule. You also need to pay close attention to your car and take note of any possible distress to your power steering. Always look closely if you hear any strange noises like whining or notice a potential leak of any kind. Make sure that you never drive your car without power steering fluid in it. To do so could completely ruin your fluid pump. Keep an eye on the color of the fluid. If it is especially dark in color then it may be contaminated and in need of changing. Fresh fluid is usually pink or amber in color. Anything much darker usually needs to be changed.
Power steering fluid does not have to be changed nearly as often as other fluids. Changing it every three to five years is often the average or as often as you change your engine coolant. A lot of work goes into maintaining a car for all of its potential lifespan, but it is well worth it.
truck has just over 40K. Yes water gets under the tires
