PCM pins
Old May 20, 2006 | 05:38 PM
timvan's Avatar
Default PCM pins
Where can I get some pcm pins....part #'s ???
Thanks!!
Old May 20, 2006 | 10:59 PM
bigdaddy1973's Avatar
sorry i have not found the pin #s yet but i have the conector "assembly" #s
c1 blue 1219489
c2 red 1219488
i will keep looking but i don't think GM gave us any pin #s
Old May 21, 2006 | 07:08 AM
I took a look on Delphi website, I have an account with them, this is what I found out.
Blue Connector - 12191489 obsolete, replaced with 15492641
Red Connector - 12191488 obsolete, replaced with 15492640
Terminal part #
12129750 Terminal Female Micro-Pack 100W Gold Plated Terminal
15359001 Terminal Female Micro-Pack 100W Gold Plated Terminal, Cable Range 0.50 - 0.35 mm2
12146034 Terminal Female Micro-Pack 100W Gold Plated Terminal, Cable Range 0.50 - 0.35 mm2
12084913 Terminal Female Micro-Pack 100W Gold Plated Terminal, Cable Range 0.50 - 0.35 mm2
15359002 Terminal Female Micro-Pack 100W Gold Plated Terminal, Cable Range 0.80 - 0.75 mm2
12084912 Terminal Female Micro-Pack 100W Gold Plated Terminal, Cable Range 1.00 - 0.75 mm2
Seal part #
12176391 Seal Orange Connector Micro-Pack 100W Seal
12146914 Seal Orange Multiple Cable Seal
Old May 21, 2006 | 07:20 AM
SnakeOiler's Avatar
12084912 is what I bought from the dealership, but it didn't look gold plated to me.
Old May 21, 2006 | 07:24 AM
How much did the terminal cost, as for being gold plated who knows, most of the terminals I get are tinned.
Old May 21, 2006 | 12:27 PM
SnakeOiler's Avatar
Unfortunately, the minimum order on waytek is $5. Still probably worth it. If you do, get the 30035
The pin I got from the dealership was $1.55
Old May 27, 2006 | 02:09 PM
iM GOING TO PUT THE EFANS IN MY TRUCK THIS WEEKEND. wHERE DO THESE PINS GO.
Old May 22, 2009 | 05:26 PM
truckmann's Avatar
Anyone who stumbles upon this should know, those pins from Waytek will not work. They are too big and will not fit in the connector.
The correct ones are the Micro-Pack 100W Sealed Terminals
Old May 22, 2009 | 05:54 PM
viciousknid's Avatar
Where's the Beef?
Good thing I didn't stumble across this earlier in my search.
Stupid me only searched the parts number list and not the entire section.
Old Jun 6, 2009 | 05:20 PM
truckmann's Avatar
http://www.eficonnection.com/eficonnection/100w.aspx
Here is another place to find the pcm pins that seems to have reasonable shipping if you only need a few and can't find them locally.
