Paint/color codes???
Old Sep 22, 2005 | 06:40 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Default Paint/color codes???
What code should I be looking for on the glovebox sticker that will tell me the color codes of my dashboard? I have a 2 tone dash Tan on the bottom and a charcoal or pewter gray on the top. Looking to buy some matching spray paint. Thanks.
Old Sep 23, 2005 | 08:34 AM
jksz71's Avatar
I don't believe that the code for the dash is on the sticker. See if you can find a good local upholstery shop in your area. They should be able to custom mix the colors you need. I had a shop mix the color for my Trans Am dash because the dash had a little fading and I had to redye it.
Old Sep 23, 2005 | 03:05 PM
454ss's Avatar
It is on the sticker but not on the bottom with the exterior paint code...., call the dealer and give them your vin code and they can tell you, or seach online for GM RPO codes and match them to the ones on your option tag.
Old Sep 27, 2005 | 12:25 PM
The interior rpo code is like 14I or 64I it usally is a #then a I just like the paint codes are #then a U. I work at a dealership if you PM your VIN i can tell you what the color is called or what code it is.
Old Sep 27, 2005 | 12:38 PM
1SlowHoe's Avatar
Default Paint code
I'll send a PM rght now. Thanks!
Pimpinpete
43
Dec 22, 2017 08:13 AM
00loudchevy
Dec 3, 2015 05:54 PM
Avalanche2002
Nov 30, 2015 07:31 AM
bearden86
26
Nov 15, 2015 03:58 PM
Pimpinpete
Sep 8, 2015 07:39 PM
