Paging Nelson Perfoprmance
Old Nov 15, 2008 | 12:53 PM
03 BLACKOUTSSS's Avatar
Default Paging Nelson Perfoprmance
I am running an Efan / Harness from you guys. The truck was tuned by Blackbear. I recently had to change the Blower motor resistor and harness. I also changed the Relays in the fan harness. I am not getting power to either fan without the AC being on??? There is no general cooling fan coming on (when the Tstat opens). Anyone have any ideas? I am stumped.
Old Nov 15, 2008 | 01:11 PM
TheMicK's Avatar
ls1truck.com is there site contact them there.
Old Nov 15, 2008 | 01:15 PM
thtanks
Old Nov 15, 2008 | 04:40 PM
budhayes3's Avatar
PT's Slowest Truck
Has pin 42 been turned on in the PCM to ground at a certain temp? If so, make sure that the pin on the blue wire is pushed all of the way in to the connector, it can be tough to get it in there.
Old Nov 15, 2008 | 06:44 PM
I found the problem...it was a so-called "new" relay. Didn't work right out of the box. Put another one in...works fine. thanks for the help.
Stainless Works
Oct 8, 2015 12:01 PM
LARRY01Z28
28
Sep 28, 2015 07:54 AM
kalikid06
Sep 20, 2015 07:46 PM
carid
Sep 10, 2015 09:07 AM
