Overheating problems with A/C on
Old Aug 15, 2012 | 10:43 PM
  #101
1FastBrick's Avatar
Custm2500's Rude Friend
Is it still blowing cold???
I found a TSB related to a hiss in the cabin
Bulletin No.: 06-01-38-002
Date: March 17, 2006
TECHNICAL
Subject: A/C System Refrigerant Hiss Noise (Replace Liquid Line) #06-01-38-002 - (03/17/2006)
Models: 2003-2006 Cadillac Escalade Models
2003-2006 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2003-2006 GMC Sierra, Yukon Models
with 4.3L, 4.8L, 5.3L, 6.0L or 8.1L Engine (VINs X, V, T, Z, B, U, N, G -- RPOs LU3, LR4, LM7, L59, L33, LQ4, LQ9, L18) and Air Conditioning (RPOs CJ2, CJ3 and C69)
Condition
Some customers may comment on a hiss noise coming from the instrument panel. The noise has also been described as sounding like a gurgle or water spattering. The noise occurs when the Air Conditioning (A/C) compressor engages and may continue for 5 to 10 seconds after the compressor disengages or the A/C system is turned off. The noise is most noticeable when the vehicle is at idle or is being driven at low speeds. The noise is undetectable after about one minute when the A/C system has been turned off or the vehicle has been turned off.
Cause
This condition may be caused by the expanding refrigerant as it passes through the orifice tube.
Correction
Technicians are to verify that the customer concern is only as described in the condition statement above. If the customer concern is a refrigerant hiss noise, then technicians are to perform the normal diagnostic procedures for an A/C system concern. The ACR2000 should be used to check the A/C system performance, charge level and discharge temperatures. This will eliminate the possibility that another condition is contributing to this customer concern. If the A/C system is performing properly, and all other possible sources of this noise are eliminated, then technicians are to replace the A/C liquid line. Use the proper part number as described in the parts information box below. Verify that the noise has been eliminated and that the A/C system operates normally.
Parts Information
Important: The trucks affected by this bulletin that have rear air conditioning were built with two different length condensers. The short condenser is 762 mm (30.0 in) long. The long condenser is 914 mm (36.0 in) long. Be sure to measure the length of the condenser before ordering one of the tubes listed below for vehicles with rear air conditioning.
Part Number
Description
Qty
15785055
Tube ASM-A/C Evaporator (vehicles with C69 and a long condenser)
Tube ASM-A/C Evaporator (all vehicles with front only A/C)
Tube ASM-A/C Evaporator (vehicles with C69 and a short condenser)
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
D3083
Hoses And/Or Lines, Refrigerant-Condenser To Evaporator (Liquid Line) - Replace
Use published labor operation time
Add
To Recover and Recharge A/C System
Old Aug 15, 2012 | 10:48 PM
  #102
oakley6575's Avatar
Yes it is till blowing cold.
I know the sound that is being described in the above post. But that is not what is happening. It is under the hood and is definitely the compressor. I will try and get a video of it tomorrow.
Old Aug 16, 2012 | 05:22 PM
  #103
Whats the head pressure doin when you rev it up to 1200 sittin still.
Old Aug 16, 2012 | 05:36 PM
  #104
oakley6575's Avatar
I would have to get gauges back on it. Not sure
Old Aug 17, 2012 | 08:52 PM
  #105
stevenc's Avatar
I am starting to think those compressor works compressors are pieces of crap.
I just placed that same compressor in my suburban and I am having a similar sound as you.
Old Aug 18, 2012 | 06:51 PM
  #106
oakley6575's Avatar
Interesting. I wonder if I should go to the junkyard and see if I can find a compressor to try just for ***** and giggles.
madmann26
Apr 29, 2020 09:17 AM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
sTNT971
Sep 26, 2015 06:27 AM
