Ok to tow 86 c1500
Hey. I wonder to see if it will be allright to tow 1986 C1500 Chevy truck 4x4 with 39" tires on it. I want to know if it will hurt my truck since my truck is 2006 Silverado 1500 5.3. I afraid if things will hurt my tranny or engine if I tow those truck 1986 c1500. I think we are going to use 4 wheels trailor. Which is more safe? If it is ok to tow. So which should I stick with 2 or 4 wheels trailor? We are from Ga. Plan to get that truck in Florida.
You will be fine, don't drive like a ass, use sense.. If you tow it use a strap, not a chain, but not for that far of a trip..If you have a trailer like ya said use that.. A tandom trailer would tow better then a single axle. Or you could get a dolly.
John |
Use your Tow/Haul mode and don't use OD.
I hauled a 3/4 ton chevy truck with a Workbed full of tools and a winch with my s10 blazer 4x4 4.3. My springs where pissed off but It did it. |
Originally Posted by viciousknid
(Post 4074591)
Put it in third and push the button on the end of the shifter. You will be fine
John |
The Tow/Haul just changes the stall and shift points so you keep momentum. Using OD with a uhaul with furniture is fine. Your talking about hauling a truck that probably weighs over 2 ton. thats a lot different than a trailer of furniture.
3rd gear, tow haul on and head on out. |
(Post 4074632)
3rd gear, tow haul on and head on out. The furinate uhual was PRETTY heavier because load of bed full and in uhual trailor a little long. Which make my truck bed pretty lower. Thats why I got freak out after you say no use OD. But I did ran od tow button for 12 hours. Last July. But my truck was fine so far. |
No he said you will be fine to haul the furniture like you did. BUT USE 3RD GEAR AND TOW HAUL FOR THIS TRIP.. You truck is fine from the previous haul job you did.. That about some it up
John |
(Post 4074671)
John |
are you using the single cab truck?
