Oil change and a tapping afterwards ?
So today, I changed my oil filter and added a quart of Mobil 1 5W-30. Got everything buttoned up and started her up. With 20,385 miles on the clock the oil pressure at hot idle was 45-50 psi. Pretty darn good in my book. Anyway I hear a tapping coming from my right cylinder bank around hole number 4, (second from the front). It sounds like a collapsed lifer or the piston slap. So I rev the engine to build a little more oil pressure(around 80 psi at 4,500rpm) and let it back to idle, to see if the noise had gone away and sure enough it did
So, my question is: Has anyone heard of lifters going bad on these trucks?
Originally Posted by Yelo
I've never heard of a lifter NOT going bad on these motors......EVERY ONE I have ever seen or worked on at one point or another has had the tapping-lifter syndrome
Originally Posted by Greggo
They are hydraulic lifters and sometimes they bleed down. I would not worry to much about it.
Corvette454l88
Sep 1, 2016 01:24 AM
Mossyoakglock
Aug 28, 2015 12:49 PM
thewrx
Aug 12, 2015 08:28 PM
Suburban2500
Jul 19, 2015 04:50 PM
