odometer and flat towing
Old Aug 25, 2012 | 12:35 PM
gowic's Avatar
Default odometer and flat towing
I've been a little curious about flat towing and the odometer reading. I have a 99 silverado 4.8, 4l60e and i bought it from an rv company. I am curious about this because the odometer reads 310,000kms but the rest of the truck doesnt really seem to match that mileage. i suspect the truck was possibly used as a pilot vehicle and had a lot of towing miles on it. i just did front brakes yesterday and they look like original pads and rotors. anyone have any insight to this?
Old Aug 25, 2012 | 01:09 PM
nonnieselman's Avatar
The odometer wont register the miles unless the key was on. And if they didnt remove the DS, the trans wouldnt last long since the fluid lubes everything. Without it, it would eat the rear bearings.
Ive seen some 99-02's with 250k+ miles still look brand new.
Old Aug 25, 2012 | 01:14 PM
gowic's Avatar
thats pretty much what i suspected thanks for the confirmation
Old Aug 25, 2012 | 01:20 PM
mhotrodscooter's Avatar
If its 4wd it could have been throw in neutral with the t-case. Still wouldn't explain how all the miles got put on there. Maybe it's wired so when the key is in the unlock position it will record the mileage so it can't be sold with low mileage. Idk
Old Aug 25, 2012 | 01:34 PM
thunder550's Avatar
High on diesel fumes
Yep 4wd's are easy to flat tow since the transfer case can be put in neutral. Also not sure about mileage being recorded when truck is off. My guess is that it's not since the PCM wouldn't be powered on, but I'm not sure.
Old Aug 25, 2012 | 01:35 PM
Petey62782's Avatar
MASS seller approved
Ask them if the gauge cluster was replaced. That could be a good exclamation.
Old Aug 26, 2012 | 08:10 PM
gowic's Avatar
well, i bought the truck at an auction so i never talked to original owner. i just noticed from the registration that there was only one owner before me and it was a RV company, so i cant say for sure what they were using it for.
Old Aug 26, 2012 | 11:33 PM
RacinRust's Avatar
How does kms compare to miles ? My 2000 rcsb 5.3 had 175K miles when I sold it. (Bad move on my part) I bought the truck new and the only brake work I did was the parking brake clips. Towed and carried loads quite often as well.
Old Aug 27, 2012 | 12:05 AM
1994Vmax's Avatar
Lol..... internet conversion maybe.
Kilometers to Miles (km to miles) converter
It works out to 187000 miles.
Old Aug 27, 2012 | 12:40 AM
RacinRust's Avatar
Very possible that is the original miles!
calsdad
Jun 14, 2023 11:07 PM
Skip Fix
22
Jul 9, 2016 07:08 PM
AdaMax
May 16, 2016 11:35 PM
cheyenne383
Nov 13, 2015 09:24 AM
zblee
Sep 17, 2015 07:58 AM
