Odd clunk in AC Box
Old Jan 18, 2014 | 08:49 PM
sprayed99's Avatar
Default Odd clunk in AC Box
2000 SCSB
I have not even started looking for the source of the noise, but thought I might post it here to see if anyone has seen this before.
So cruising down the road and I roll down the window. With the pressure change in the cab I hear a clunk noise coming from the AC box. What I suspect is the recirculate door is slamming shut.
I also have a outside air draft when at 50mph+ and a very small leak when it sits in the rain. I suspect these 2 issues are related to a bad cowl panel seal on the passenger side.
Anyone run into this before?
Thanks
Old Jan 18, 2014 | 11:37 PM
AUTOT3K's Avatar
when you switch from recirc to outside does it make noise at all?
the water leak would probly be from a bad cowl seal
but the clunk does kinda sound like a recirc door issue
Old Jan 18, 2014 | 11:49 PM
sprayed99's Avatar
I agree on the cowl seal.
It does not make any noise when it is switched however it could not even be moving.
Old Jan 19, 2014 | 09:19 PM
AUTOT3K's Avatar
ya I could see a broken linkage and when you open the window the pressure slams the door
sucks that its not an easy "open it up and check" situation!
Avalanche2002
Nov 30, 2015 07:31 AM
dsbodley
Nov 14, 2015 09:46 PM
Wrecker 426
Oct 7, 2015 12:11 PM
Infernohoe
48
Oct 2, 2015 10:25 PM
BCraven1018
Oct 1, 2015 08:22 PM
